Greetings! Thanks for the excellent software!
When I forward a QSO generated by Ham Radio Deluxe's logbook (I need it because of RTTY) over UDP connection, LOG4OM does not correctly understand the stream of numbers sent by Ham Radio Deluxe to designate the QRG. For example, when logging a qso in the HDR in the QRG of 700099 (40m band) Log4OM understands it as 70009,9 (And he put 4m band in log) when receives de UDP. I did everything I could, but I couldn't solve the problem. What should I do?
Thank you very much!
73!
LOG4OM does not correctly understand the QRG
- PY6FX_20230324151935.zip
- (28.43 KiB) Downloaded 36 times
Re: LOG4OM does not correctly understand the QRG
what happens if you export those contacts to an adi file, then import into log4om. does that way get imported correctly?? if not I would be looking at hRD adi file ansee how it is in the file
it may be hrd's fault and not log4om
I'll try it out and post the result here. Thanks!
