Single field update
KB1FGC
Single field update
Post by KB1FGC »
Hi,Is there a way to update LOTW sent and received columns as a single field like there is in the QSO menu?
Thanks Rich
73 KB1FGC
Re: Single field update
KB1FGC wrote: 24 Mar 2023, 21:01 Hi,Is there a way to update LOTW sent and received columns as a single field like there is in the QSO menu?
Rich,
Use QSL Manager and select the LOTW dropdown, select the Q's you want to modify and also check the enable update option.
Now ... if your Confirmations are properly set up once you upload your Q's to LOTW they will be changed by Log4OM. Same goes for when you d/l your confirming Q's from LOTW.
KB1FGC
Post by KB1FGC »
Hi Nolan thanks for the email.I updated it bit it still shows a lot of QSO's as
Sent: yes
Received:no
It did improve a little.Out of 635 before,3 reflected the change.
I am not sure but,I understand that LOTW will reflect new changes on my received end.But I thought I control the sent status.Is that right?
I had made the mistake of loading all my QSO's way back and now 632QSO's show a sent status.What I wanted to do is change that status since most of them I do not need a LOTW confirmation and most of the stations don't use LOTW.It was a mistake on my part.
I was hoping to change the 632QSO's as:
Sent: NO
Received:NO
Is there something I am doing wrong when changing the SENT status?
here is what LOTW says when I tried uploading and then downloading a known file to be logged in LOTW:
Begin FULL ADIF generation request
Login KB1FGC
Begin ADIF download. May take some time...
RESPONSE file downloaded...
Parsing FULL ADIF file...
ADIF FULL document parsed: 1 qso found.
SEARCHING FOR NEW AWARDS...
SAVING FULL QSO's...
SAVE COMPLETE
LOTW UPDATING STATISTICS...
LOTW END
Thanks for your continued help
73 :D
Thanks Rich
73 KB1FGC
KB1FGC
Post by KB1FGC »
Hi Nolan,I figured out how to update LOTW.Thanks.For some reason It doesn't seem to work when I update QSO's using the button on top of the window in the QSL manager.But It works when using my keyboard/I will post another issue I have
Thanks Rich
73 KB1FGC
Rich,
Just in case you have not yet done so ... take some time to watch Terry's 3 YouTube Videos about Confirmations.
He goes into great detail about how the Yes/No, etc., etc. works with the saved Q's.
Here is a link to all his Y/T videos. There are "3" that focus on Confirmations.
https://www.youtube.com/channel/UC6Ppcj ... yavI-azOug
KB1FGC
Post by KB1FGC »
Thanks Terry
Thanks Rich
73 KB1FGC
