In
"Configuration"
"User Configuration"
It would be great, if You yould add the description in the pulldown menu, as it only shows at the moment the configuration ID.
Problem: by using several Configurations (e.g. for SOTA), the User must check several of the configs until the correct one could be found.
Benefit: by showing the description in the pulldown menu, user can see directly the targed ID-Line (see picture)
Add Description in UserConfiguration - PullDown
Re: Add Description in UserConfiguration - PullDown
Daniel,
There is a label box for each configuration ID. Does that not work for you?
No matter what ID I click on the descriptor of what I provided when creating the ID is in the box?
- config-ID-label.JPG (73.15 KiB) Viewed 1485 times
Hi Nolan
There is a label box for each configuration ID which shows the ID AFTER the selection in the pulldown menu. You will need to test the different config ID's to find the correct one (desciption will be showned, after the selection and not during).
Daniel
Daniel
Daniel,
But tapping on the ID to then allow the view of the description does not mean you have had to engage that ID. It is just a stepping through the various Configuration IDs to see the description.
Albeit ... (unfortunately) it is an extra click or two rather than your proposed labeling.
The current description field has been a recent addition (also from OM feature requests) so will have to see what the programming possibilities are from Lele.
This request has been added to an upcoming release.
We're testing it now.
Hey team
Really appreciate this and Your work.
Best 73 de Daniel
Best 73 de Daniel
Hello team
Very cool that this option was added in the latest release.
Thank You very much and best 73
Daniel
Daniel
- 11-06-_2023_10-05-45.png (33.62 KiB) Viewed 1307 times
