I am running latest beta and upload to QSOMAP.com via OUTBOUND UDP ( see screen shot).
After the beta update I noted the QSOMAP.COM website was not updating, as the destination ip address had reverted to 127.0.0.1 from the required ip 66.208.64.118. Deleting and recreating the outbound rule to the correct IP, only sees it reverting to 127.0.0.1 everytime.
I wonder what has changed, and how do I get the correct IP to sticK? Any ideas would be appreciated?
Gavin
ZL3GAV
OUTBOUND UDP/BETA
- ZL3GAV
- Advanced Class
OUTBOUND UDP/BETA
- OUTBOUND UDP.png (26.75 KiB) Viewed 1078 times
Re: OUTBOUND UDP/BETA
I'm wondering if you're forgetting the port and it's resetting due to invalid configuration.
- ZL3GAV
- Advanced Class
Thanks, the port 12070 was the correct port before, and after the beta update, and is the address advised by QSOMAP.com.
Gavin
ZL3GAV
Gavin
ZL3GAV
When QSOMAP.ORG moved to QSOMAP.COM on Amazon Web Services, its IP address changed. The QSOMAP.COM IP Address is now 34.239.34.181. It would be better to use the DNS name of QSOMAP.COM instead of its IP address if Log4OM can use that instead.
For QSO Forwarding use either QSOMAP.COM or it's new IP Address 34.239.34.181 on Amazon Web Services
