FlDigi not working with Log4OM and Win4Yaesu Suite
W2JAZ
Post by W2JAZ »
I nearly have this suite of programs working perfectly. Win4Yaesu is communicating now fine with Log4OM and WSJT-X. I am able to get FlDigi to receive signals and track the radio frequency but am unable to get PTT to work when I go to transmit. I'm obviously missing something in the setup but have not yet found a solution.
Can anyone help?
Rick, W2JAZ
Re: FlDigi not working with Log4OM and Win4Yaesu Suite
Rick,
Have you looked (I'm sure you have as I recall earlier posts) at the U.G. (newest release dated June 05, 2023 3:55PM) on Page 233?
That information was provided to us by Tom - VA2FSQ who is the developer of those suites of radio control programs.
Also there are a couple PTT options in Log4OM at: Settings / Configuration / CAT Interface
I can only suggest sources of information as I've never had a need to use one of the 'suite' programs.
ve3wej
Post by ve3wej »
I usually have fldigi working here, using log4om, win4yaesu ( with seperate virtual port ) but I am using flrig at the same time. I would have check my settings
I do not run wsjt at the same time as fldigi. never found a need, as both programs send data to log4om, I dont need to log it in fldigi
