Cluster Map not showing spotted station
F4HGU
Post by F4HGU »
I am connected to a cluster whith a lot of spotted stations .
When I click on the map I see only one square which looks to be my own QRA locator.
Any trick to populate the map with the other stations ?
Thanks and Regards,
Patrice F4HGU
Re: Cluster Map not showing spotted station
Patrice,
There is a QSO Map available on the Recent QSO's (F7) Tab.
There not a provision to show "multiple" spots on the Main F6 tab panels.
However when you enter a callsign into the Main UI the two maps will change and show a path and also a more close view of the DX station.
F4HGU
Post by F4HGU »
Hello Nolan,
Thanks a lot for your time and your detailed answer. I am not talking about those maps, but the cluster map as shown in the usuer manual:
On my side I do not see any red squares (only my QRA) while the cluster is running and showing a bunch a spots in the table.
Regards,
Patrice
F4HGU wrote: 27 Sep 2023, 07:40 Hello Nolan,
Regards,
Patrice
It wont populate until the next cluster refresh
F4HGU
Post by F4HGU »
Noted, I'll check once again tonight.
Thanks,
Patrice
F4HGU wrote: 27 Sep 2023, 07:48 Hi Terry,
Thanks,
Patrice
Patrice,
I should learn by now not to comment before I check :oops: :oops: :oops:
Just confirmed none of the maps attached to the cluster views are populating with the spots just the home station.
I will speak to Lele about this
F4HGU
Post by F4HGU »
Thank you Terry, I was coming here tonight to tell you it's still not showing anything after an hour, but you came to the same conclusion too. :D
Good luck for the fix !
Regards,
Patrice
something optimized too much... :-(
Is the "cluster throttling" message displayed on cluster screen (bottom area)?
While throttling is enabled, the map is not updated to avoid stressing the system with several graphics updates on the background (until i'll move to DirectX...)
if a skimmer is in use this is a common scenario.
You can change this behaviour in the SETTINGS screen under PERFORMANCE tab
Please let us know if that fixes
