WAC shows 2 continents as W but have cfmed QSO's
Moderator: OE6CLD
k4em
Post by k4em »
Under the 6m column my Award Status/WAC shows AF & SA as 'W', I have confirmed QSO's for those Continents. I tried, Rescan QSO References & Rebuild Statistics and searched the forum for any info. No luck finding anything that helped.
I looked closely at the QSO's for any errors; zone, grid, dxcc #, etc, all seems normal for the confirmed qso's.
Dave
k4em
N6VH
Re: WAC shows 2 continents as W but have cfmed QSO's
Post by N6VH »
Dave,
After reading your post, I checked and I have the same issue. In my case the continents only showing as worked are OC and SA. In both cases they are confirmed on LOTW. I regularly do a download from LOTW, so that isn't the problem.
Jim N6VH
OE6CLD
Post by OE6CLD »
Hi Dave, hi Jim,
Please download/update the WAC award definition and rescan - should work now.
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
k4em
Post by k4em »
It's working now, Thanks Claus.
Dave
k4em
N6VH
Post by N6VH »
Claus,
That did the trick. Thank you.
Jim N6VH
