Looking to get Log4om to upload each qso to Cloudlog using ADIF POST function.
Please can some one give me the correct syntax to input into the target url.
There also needs to be an api key field and an id field.
Any help would be much appreciated.
Thank you.
Cloudlog ADIF POST settings please
Re: Cloudlog ADIF POST settings please
Why do you want to upload to cloudlog its another logger?
What does Cloudlog provide that is not already in Log4OM?
How are you trying to upload, Export and import, using UDP or what?
Is there a UDP or similar provision for integration with other loggers provided in Cloudlog?
I am actually doing this so I wrote a small golang program to do exactly this but also upload to clublog and upload to QRZ.com.
I can share if you want if you are able to build the executable file on go
73 de XV9Q Greg
You could probably also have this working with Aurora Cloudlog by the way (not sure it works but it handles UDP)
73 de XV9Q Greg
