Hello all,
I need some help, probably a minor setting but I cannot figure it out.
I moved LOG4OM over to a new computer and thought everything was working but it looks like LOTW is trying to upload but not able. Check the TQSL.exe path and OK. I am running as ADMIN.
Here is the offending section. Also attached is the log file. Any help is appreciated. Thx
2024-01-18 17:29:00.9604 ERROR: [LOTWManagement][UploadLog] : [LOTW UPLOAD] ERROR: Creating temporary folder for LOTW upload: C:\Users\dropbox321\Documents
[EXCEPTION] Access to the path 'C:\Users\dropbox321\Documents' is denied. System.UnauthorizedAccessException: Access to the path 'C:\Users\dropbox321\Documents' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.Directory.InternalCreateDirectory(String fullPath, String path, Object dirSecurityObj, Boolean checkHost)
at System.IO.Directory.InternalCreateDirectoryHelper(String path, Boolean checkHost)
at System.IO.Directory.CreateDirectory(String path)
Trouble getting LOTW to upload, access to Document folder denied
Thanks and God Bless,
Phillip KQ4AJI, 73
ICOM-7300 with a 40-20-15-10-6 Fan Dipole
Phillip KQ4AJI, 73
Re: Trouble getting LOTW to upload, access to Document folder denied
I dont know how many times I need to say this but please DO NOT add your log files to forum posts, they contain your private information that can be used by scammers I have deleted it!
Your issue is because the locationj you specified in the config of Log4OM for storing your temporary files for LOTW is a secured location, please change it to
C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\LOTW
or
C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\temp
or
Thanks Terry,
Item #1, Roger Roger!
Item #2, Thanks for the detail on locations.
Phillip KQ4AJI, 73
Phillip KQ4AJI, 73
