LOTW upload issue
pa3adu
LOTW upload issue
Post by pa3adu »
Run a contest using N1MM and uploaded the Adif file into LOG4OM2. Worked fine and tried to send conformation to eQSL and LOTW. The eQSL upload worked fine but the LOTW upload fails. When I get into the window Upload "confirmations" and hit the green button, immediately getting the message "LOTW END". When I try again, I stil see that there are same number of QSO's to update. Checking LOTW web page, no QSO's are updated.
Checked my settings but can't find anything that has changed.
Any suggestions?
Nico PA3ADU
Re: LOTW upload issue
What is the LotW sent status after importing from N1MM and what is your setting in Log4OM ? If you have a Quequed or Requested
from N1MM and your setting in Log4OM is NO QSO´s wan´t be uploaded.
pa3adu
Post by pa3adu »
Thank you Jeurgen for thereply.
I have forced to change the "Sent" setting and it is working again!
Nico PA3ADU
