Change of callsign and logs
Pa0ply
Post by Pa0ply »
I will set up a new log for a clubstation on a new computer.
We do have an adif file with a lot of stations logged.
We would like to import this log.
That should not be a problem, however we may face to the following situation soon:
- the clubstation callsign will change soon.
Q: How can I change this?
Q: As the log was imported for the old clubcall, what will happen to this log?
Br. Jan, PAoPLY
JA9HWD
Re: Change of callsign and logs
Post by JA9HWD »
Pa0ply wrote: 01 Apr 2024, 17:15 Hi,
Br. Jan, PAoPLY
I think you can import the current club station log normally and create a new profile in the user configuration after the call sign changes.
Before changing your call sign, complete the eQSL and LoTW account settings and common settings. Create a new profile based on this profile when you change to a new call sign.
Don't forget to switch profiles when processing different callsigns (uploading and downloading eQSL, LoTW, etc.).
This way they should be treated as different things. I don't know anything about award management.
73, Kiyo JA9HWD
