Edit QSOs and Edit UDP paths doesn't work
N4RF
Post by N4RF »
When I try to edit QSOs (i.e. right click on QSO in Recent QSO's), I get the page EDIT QSO, but it is blank (in the tool bar only) and not executable. Same for trying to update my Incoming UDP paths. I changed to run as administrator and still nothing.
Bob N4RF
Re: Edit QSOs and Edit UDP paths doesn't work
Try a clean install of the latest Beta version please
N4RF
Post by N4RF »
I am on version 2.32.1.0
I couldn't find any other beta version to upload.
Bob
So a fresh download of that version and then a clean install
N4RF
Post by N4RF »
I did install the latest version of Log4OM two times with no results.
I may have a problem with my computer.
Bob N4RF
N4RF wrote: 24 May 2024, 17:48 I did install the latest version of Log4OM two times with no results.
Bob N4RF
But did you do a clean install by removing all user files in addition to uninstallig the software?
Obviously after making backups for security
N4RF
Post by N4RF »
For backing up, do I just do that under the file menu and then uninstall from the program file section.
I am nervous, hi. I need Doug NN7Dd, hi. I am so unskilled with computers. Just a simple minded CW guy.
Bob N4RF
N4RF wrote: 25 May 2024, 11:07 For backing up, do I just do that under the file menu and then uninstall from the program file section.
Bob N4RF
Hi Bob,
Then best to not try this but rather find someone locally who could fix it via teamviewer or similar
N4RF
Post by N4RF »
I uninstalled Log4OM and reinstalled it. I still can not edit a QSO or UDP.
For some strange reason every QSO is being logged twice. I thought my incoming UDP needed to be changed.
I have ADIF Message JTAlert Logging 2235, JTAlert Rebrodcast 12040 and N1MM Message/Logging 12060. The manual has different numbers (addresses?), but Log4OM won't allow me to edit the UDP Inbound Connections. They are a blank page in the tool bar. Clicking on them does nothing.
You edit them in settings/program config/connections
Screenshot 2024-05-25 173349.png (36.81 KiB) Viewed 474 times
