Log4OM 2 2.4.0.0 Released
All relevant news related to Log4OM software will be published here.
Post by IW3HMH » 03 Mar 2020, 17:13
Release note – Version 2.4.0.0
• [NEW] Added Clublog/CTY file exception correction on all cluster items
• [NEW] LazyLog massive data entry interface added
• [NEW] ADIF export can now produce files with a reduced, user selectable, range of fields (File -> Export ADIF)
• [NEW] Added CSV export with user selectable/sortable fields (File -> Export CSV)
• [NEW] Option to invert FREQUENCY/MODE order in message sent to radio (Settings – CAT)
• [NEW] Added native support for network connected rigs through Hamlib (FLEX and similar)
• [NEW] Added SOTA Chaser/S2S/SWL TSV/CSV file format export capabilities (Award Statistics screen -> Export)
• [NEW] Added “stay on top” option on contest and winkeyer screens
• Added management of award reference alias. Will affect correct identification of USA-CA award references and others.
• ADIF and CSV export is now available also in QSO Management with full output filters
• Improved EQSL and LOTW import performances
• Improved WSJT/JTAlert ADIF inbound message performances
• Improved reactivity of QSO add function. QSO save is made asynchronously respect main UI
• Added management of the (now deprecated) QSL_SEND status "Validated". This will mark all LOTW and WAS references as VALIDATED.
• New option in Alerts: Ignore statistics. Trigger the alert under any condition of worked/confirmed for the country
• Import of QSL_RCVD status Verified (actually deprecated in ADIF standard) now set the QSO as VERIFIED for DXCC and WAS
• Added option to start Hamlib application hidden (not shown on taskbar)
• Previous QSO and Worked Before no more on top by default
• small fixes in LOTW download interface
• QSO filters improved: Added capability to explicitly exclude QSO that have a specific award in the myReference/contactReference. Useful to extract chaser without ref2ref contacts.
• Clearing Callsign field in main UI resets map to station home QTH
• Updated SOTA routines to support new summits csv file from SOTA website
• [FIX] Massive QSO update performance issue fixed
• [FIX] grid field editor no more stay behind the parent screen if parent is set to stay on top
• [FIX] Length reported in ADIF format for frequency was incorrect
• [FIX] Omnirig dual radio - one off issue fixed
• [FIX] Award statistics view (chaser / activator / reference2reference filters)
• [FIX] Prevented removal of QSO primary keys (date/callsign/band/mode) at database level
• [FIX] My Rig and My Antenna not correctly retrieved when using a different profile in QSO Edit
• [FIX] Reported length of ADIF fields now consider // as start of the comment and exclude comment length from adif field calculation
• [FIX] Hrdlog sends online status even with not active.
• [FIX] Changes in Winkeyer UI won't trigger main UI interface refresh, stealing focus
• [FIX] Current references in QSO under edit are not cleared if main parameters (band/mode) changes. User must check if current awards registered are still valid for the QSO even under new parameters. DXCC change always clear preselected awards
