Version 2.13.0.0 released
All relevant news related to Log4OM software will be published here.
Post by G4POP » 03 May 2021, 06:41
Known issue with Excel buttons not saving will be fixed in next release
Release note – Version 2.13.0.0
[NEW] Added export to excel button on grids
[NEW] Introduced caching for external sources and callsign statistics
[NEW] Added automatic cluster disconnection when counterpart become unresponsive
Updated Bonair Island flag
Hamlib rigs are now alphabetically sorted by manufacturer-model
Added frequency on email alerts
Spots can now be sent to localhost if log4om local relay server is offline or uses a different port than the targeted one
[FIX] Removed <BR> from email alerts and switched to plain text
[FIX] Fixed an issue that prevented alert email on some circumstances
[FIX] Fixed an issue that in some cases used the wrong state from external sources when the callsign is decorated with a prefix
[FIX] Fixed label print label reporting user was not exchanging QSL with correct behaviour
[FIX] ADIF import counter is now showing the correct amount of QSO imported
[FIX] Winkeyer QSO references is now properly filled with data
[FIX] Fixed winkeyer macro issue that prevented some strings to be sent correctly (first character sent issue)
[FIX] Fixed Hamlib MODE swap issue and other minor things
[FIX] Included a new Hamlib version with many fixes on specific rig drivers that should fix the “VFO SWAP” issue. More info and specific reports can be addressed to Hamlib software team.
