Page 2 of 2
Re: Fldigi logging fail
Posted: 01 Oct 2014, 17:07
M1BCM wrote:G4POP wrote:My guess would be that you created a new logbook in FLDigi, check the folder containing the FLDigi logs to see if you have more than one adi file, possibly one called new logbook.
If you have then in FLDigi change to logbook.adi, restart the programs and see if it works
Terry, i'm having the same problem and i can't see anywhere in Fldigi settings to change logbook.adi.
Also which directory is the default for the logfile
73 Jeff M1BCM
This is from memory because I am on holiday in Cornwall but....
with windows XP ------ C:\Documents and Settings\YOUR USER NAME\fldigi.files\logs
Win 7 or 8 -------- C:\users\YOUR USER NAME\fldigi_files\logs
Posted: 09 Oct 2014, 16:02
by M1BCM
M1BCM wrote:G4DWV - Guy wrote:Hi Jeff,
This is how I fixed the problem, IIRC. You have to enable the 'name' column in Log4OM. Press 'F8' to get to recent QSO tab. On the bottom left there is a button labelled 'Layout'. Click on it and you should be able to navigate what pops up. Just add the 'name' column and all should be well.
Guy G4DWV/4X1LT
Cheers Guy, problem is that the name column was
already enabled .. problem is still there
Jeff M1BCM
I
STILL have this problem, FLdigi just
WON'T log to Log4OM .. can anyone help out ?? i've gone thru the settings and suggestions listed above .. but still no help
Cheers Jeff M1BCM
Posted: 09 Oct 2014, 22:05
Email me direct and we will talk on Skype
