JT-Alert scan log not updating
WA1NRA
Post by WA1NRA »
I am running Log4OM and JT-Alert with CAT from my G11 SDR. All is working fine. BUT, when I try to update my wanteds on JT-Alert by scanning my Log4OM log, it will not credit my band/mode contacts and upodate the Wanted lists. JT-A logging is enabled and logs QSOs directly into LOG4OM fine.
Why is the update not updating?
Could it be that JT-A is not reading the log, but writing fine? During the JT-A scan/update from the log, scans seem to run fine visually, but don't update the Wanted list.
Thanks, Duane WA1NRA
Re: JT-Alert scan log not updating
You need to ask the author of JTAlert about this because JTAlert scans the database, providing you have selected the correct location of the database in JTAlert?
We don't send information to JTA, JTA scans for it, so if it's not scanning correctly it's because something is wrong in JTA
