Page 4 of 4
Re: Integration with HDSDR
Posted: 20 Apr 2014, 18:30
by EI2GLB
I'll drop you a note during the week Terry minding the baby over the weekend so very little time for radio,
Trevor
Posted: 04 Dec 2016, 01:46
by K9AQ
What was the final solution for this integration? I am running into the same problem. I have an Elecraft K3 which is using Win4K3Suite for rigcontrol and for multiple "virtual" K3's. I have a virtual com pair set up with com0com Com 20 and Com 30. Com 30 connects to an aux/com port in Win4K3Suite (which is a clone of the actual K3). Omnirig connects to com 20. I can then connect it to either Log4OM or HDSDR but not both. It doesn't matter what order I start them in.
I use HDSDR with SDR Play, which connects to the IF output of the K3.
How do I get Log4om to work with HDSDR?
Don
K9AQ
Posted: 04 Dec 2016, 14:30
by K9AQ
Thank Trevor.
By the way I checked my Internet security and I am using AVR, which I saw in the post may also be a factor. I will be looking forward to getting your note. I spend the weekend setting up HDSDR with SDRPlay as a sub receiver for my Elecraft K3. It works very well, but I would like to get Omnirig working again with Log4OM.
Don
K9AQ
Posted: 14 Dec 2016, 20:24
by K9AQ
Trevor
I haven't heard back from you on this issue.
Don
K9AQ
Posted: 28 Dec 2016, 18:16
Try running all software with admin privileges.
This often solves the concurrent access to Omnirig
Posted: 29 Dec 2016, 14:37
by K9AQ
I thought I had tried that already but I will give it another try.
Don
K9AQ
Posted: 29 Dec 2016, 14:53
by K9AQ
That worked! Thanks, I should have thought of trying that.
Don
K9AQ
