Dupe checking with FLDIGI
Posted: 07 Oct 2016, 18:59
I see elsewhere in the forums that LOG4OM cannot automatically check for previously worked callsigns when using FLDIGI unless the callsign appears in the cluster window. As a recent HRD convert this feature is sorely missed and I'm wondering how others are addressing dupe checking before you call a station? I've seen receive window popups mentioned in the FLDIGI documentation but nothing happens when I cursor over a callsign. Is copy /paste the only option?
Rick KW0RH
Rick KW0RH
