List of ADIF tags accepted in a Log Command?
VK3AMA
Log4OM Beta Team
Post by VK3AMA » 24 Feb 2013, 20:07
Is there a list of the adif tags that are supported when performing a log command using the UDP method?
During testing for JT-Alert it has been noted that the TX_PWR, QSL_SENT, QSL_RCVD, LOTW_QSL_SENT, LOTW_QSL_RCVD, EQSL_QSL_SENT and EQSL_QSL_RCVD adif tags are ignored in the adif record.
de Laurie, VK3AMA
Re: List of ADIF tags accepted in a Log Command?
Post by IW3HMH » 24 Feb 2013, 20:59
Hi Laurie.
Log4OM reads all parameters from ADIF but on import from external sources many of those was empty and will be overwritten with the "user configured parameters".
I'm changing the function to keep informations from external sources if available.
That was a very rare case (usually external software sends very small informations to loggers) and i'm taking care of this.
The updates will be available on the next release, but i will be glad to share an alpha with you if you can do some tests.
Daniele
VK3AMA
Log4OM Beta Team
Post by VK3AMA » 24 Feb 2013, 21:55
Hi Daniele,
I will wait for the next release. These issues are not critical.
BTW, JT-Alert only includes adif tags if they contain valid data. There are no empty tags.
de Laurie, VK3AMA
