Guys, finding the instructions a little scant for my limited PC knowledge, can someone contact me off line for a quick set up? My main issue is having rig control in both programs; do I need to run a virtual serial port?
thanks
Paul
FLdigi integration
Re: FLdigi integration
If you require rig control in both program's you will require a VSP try the free Eterlogic one
When using Log4OM with Fldigi and VSPE, the frequencies passed to Fldigi are for FSK RTTY mode. I would like to pass the correct frequencies for AFSK using USB mode. Is this option currently available or must I request a change to the software?
The DXLabSuite programs DXView and SpotCollector using the Fldigi-DXLabs Gateway software by N2AMG allow you to set the mode to USB and pass the frequency which is 1.5 KC's lower than what you pass in Log4OM.
In case you haven't interfaced Fldigi-DXLabs Gateway software here is the site:
http://www.n2amg.com/software/fldigi-dxlabs-gateway/
To get the Gateway program working with SpotCollector and Fldigi you must enter the program name in the the Digital Mode Application in SpotCollector and press CONNECT. The following is the path for the configuration change:
Config
General
GREAT software just needs a couple of tweeks to make it PERFECT!
David - WA8KHP
Config
General
David - WA8KHP
The Fldigi integration is being updated to provide full CAT control and support
You can change the Omnirig ini yourself for your radio to use USB instead of RTTY
The user can also edit the Bandplan for his region to change the frequencies used for different modes
If you are having problems editing the Bandplan let me know the frequencies that you need to be USB and I will do the edit for you
