Hi all,
Please find attached the award definition for the DDFM - Départements français de la métropole. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_DDFM.xml) into the <user>/AppData/Roaming/LogOM/awards folder (or in the config/awards folder if you're using the portable version) and restart Log4OM.
Starting with version 1.18.0 Log4OM will update all awards automatically, there is no need to copy the awards file to a specific folder. We really would recommend to update to this or any newer version!
More information regarding the award can be found here: http://www.r-e-f.org/index.php?Itemid=294
Claus, EI7JZ/OE6CLD
Moderator: OE6CLD
Claus, OE6CLD/DJ0DX/EI7JZ
Re: DDFM - Départements français de la métropole
Hi Claus,
I am struggling with this award.
I installed Log4OM Portable version 1.21
I do not find how to make this award accessible in Log4OM.
I tried to put DDFM.xml in the folder Log4OM/config/awards as you mentioned but it is not working
Then tried also in Roaming/LogOM/awards but not working either.
Tried to put also in Log4OM/awards but still no chance.
Tried to update awards database and no more chance.
Could you please help ?
Greg
Greg
73 de XV9Q Greg
Hi Greg, let me check if it works on my installation...
Hi Danielle,
Cannot get this Award back and working since I formatted my computer and installed the portable version.
Anyway before i had it working with the 1.20 portable version (I only use this one cause i prefer to put it on the cloud as it includes the config files)
If you find how to make the DDFM to work let me know
73 de XV9Q Greg
Did you use the File/import facility in the awards manager window?HS0ZLE wrote:Hi Claus,
Greg
I did not as it seems we can only import a csv file not xml
73 de XV9Q Greg
As I said File Import (Here you can import an Award from xmlHS0ZLE wrote:I did not as it seems we can only import a csv file not xml
