QSL Management Regression
AE0S
Post by AE0S »
I noticed that a few common operations that I'm doing quite often require more steps than before.
Case: Marking Received QSL Cards as Received
I individually mark every QSL Card as received as I'm getting them.
Old way (8 steps)
Code: Select all
In QSL Management
1. Enter callsign
2. Click "Search" button
3. Double click QSO row
4. Click "QSL Information" tab
5. Set "Received" to "Yes"
6. Check/set date
7. Choose "Direct" in "QSL Received via"
8. Click "Save and Exit" button
New way (10 steps)
Code: Select all
In QSL Manager
1. Enter callsign
2. Double click QSO row
3. Click "QSL Info" button
4. Choose "QSL" in "Manage confirmation"
5. Set "Rcvd" to "Yes"
6. Check/set date
7. Choose "Direct" in "Via"
8. Click save button for this QSL type
9. Click save button of "Edit QSO" window
10. Close "Edit QSO" window
Case: Uploading LoTW QSOs
I don't upload QSOs until I'm done working on the radio. That way I can correct stuff if needed.
Old way (5 steps)
Code: Select all
In QSL Management
1. Click "LOTW" button
2. Click "Select required" button
3. Click [Up Arrow] button
4. Click "Upload" button in upload window
5. Close upload window
New way (7 steps)
Code: Select all
In QSL Manager
1. Choose "LOTW" in "Search confirmation"
2. Check "Sent" (filter)
3. Choose "Requested" (for sent filter)
4. Click "Select/deselect" to select all records
5. Click "Upload selected QSO" button
6. Click [Up to Cloud Arrow] in upload window
7. Close upload window
Any chance that the user interface of Log4OM V2 will be optimized for usage?
Re: QSL Management Regression
Yes,
a "QSL received workflow" is planned to be implemented, as well as the "select all required" for upload
