Wrong bandplan
VE1GPY
Wrong bandplan
Post by VE1GPY » 19 Jan 2020, 18:00
When I move my VFO above 7.2Mhz on 40M, the "Band" field is blanked out and a red alert icon appears. This makes it look like it's using a region 1 bandplan even though I have my IARU Region set to 2. I confirmed this by temporarily editing the <user>/AppData/Roaming/Log4OM2/bandpland/bandplan_r1.xml file - which corrected the "Band" field behaviour.
Any idea why it's using a region 1 bandplan and what I might do to change it?
Thanks and 73,
Sheldon VE1GPY
Re: Wrong bandplan
Post by G4POP » 19 Jan 2020, 18:14
Did you click save and apply and did you restart Log4om?
VE1GPY
Re: Wrong bandplan
Post by VE1GPY » 19 Jan 2020, 18:31
Thanks, Terry.
Yes to both.
VE1GPY
Re: Wrong bandplan
Post by VE1GPY » 19 Jan 2020, 18:55
In the <user>/AppData/Roaming/Log4OM2/user/config.json file, I found
Code: Select all
IaruRegion:1
I did a hand-edit to make it 2 and the problem resolved. It looks like the value was not written correctly by the Settings/Program Configuration screen on save and apply.
I confirmed this by using the UI to change the value to 1 and doing a save and apply and a restart of the program. The value in the JSON didn't change. Did it again with a value of 3 with the same result. In both cases, the value in the JSON remained as 2 (from my hand-edit).
Sheldon VE1GPY
VA3AG
Re: Wrong bandplan
Post by VA3AG » 19 Jan 2020, 18:58
VE1GPY wrote:
19 Jan 2020, 18:55
Code: Select all
IaruRegion:1
Sheldon VE1GPY
Glad you resolved the issue. Enjoy!
Aldo VA3AG
W7DRM
Re: Wrong bandplan
Post by W7DRM » 19 Jan 2020, 23:56
VE1GPY wrote:
19 Jan 2020, 18:55
Code: Select all
IaruRegion:1
Sheldon VE1GPY
Hi Sheldon,
I've replicated this behavior. A fix is forthcoming... thanks for reporting!
Doug
W7DRM
