Hi all,
I am using a FTDX 3000 with MicroHam MK2R+ and Log4OM 2.1.0.0, i am facing an issue while jumping from a cluster from USB to LSB or vice versa which gives incorrect frequency.
I do not have the issue with Log4OM v1.40 with exact same setup.
you can see the video here:
https://youtu.be/noTnEterm2U
[2.1] CAT Cluster Frequency discrepancy
73 de F4BPO Greg
Re: [2.1] CAT Cluster Frequency discrepancy
Up
So it seems i am the only one having this issue ?
73 de F4BPO Greg
Hi Greg,
I use Log4OM Version 2.2.0.0 and I've not a problem with changing frequencies. I looked at the data stream and saw that Log4OM Version 2.2.0.0 sends the right frequencies.
Please try Log4OM Version 2.2.0.0 und test again. Let us know the result.
73 de DJ4JZ
This seems to be a general problem with Yaesu rigs. I have the same issue with my FT-950. and others have reported similar issues in the forum.
If clicking the cluster causes a change of mode, then the resulting frequency is offset. Double-clicking the cluster again sets the correct frequency because the mode doesn't have to change.
I wrote a CAT program recently and found in general for the FT-950 that if the frequency is changed before the mode, then the resulting frequency is wrong, but if the mode is changed before the frequency then it is ok. Seems like a CAT commend sequence issue that may be unique to Yaesu ?
Graham, M0VON
Graham, M0VON
Thanks Graham for explanation.
I am of course using 2.2.0.0 to reply to DJ4JZ.
OK so for now I will remain on v1 as it is perfectly working on v1. Hope this can be addressed by changing mode first before frequency.
Thanks again
Thanks again
73 de F4BPO Greg
Checking on this. There is an option in V1 to send Freq before Mode. I can't find that option in V2... I've asked Danielle...
Doug - W7DRM
Doug - W7DRM
Thanks Doug as this is a real problem to be honest
73 de F4BPO Greg
