[2.1] CAT Cluster Frequency discrepancy
F4BPO
Post by F4BPO »
Hi all,
I am using a FTDX 3000 with MicroHam MK2R+ and Log4OM 2.1.0.0, i am facing an issue while jumping from a cluster from USB to LSB or vice versa which gives incorrect frequency.
I do not have the issue with Log4OM v1.40 with exact same setup.
you can see the video here:
https://youtu.be/noTnEterm2U
73 de XV9BPO Greg
F4BPO
Re: [2.1] CAT Cluster Frequency discrepancy
Post by F4BPO »
Up
So it seems i am the only one having this issue ?
73 de XV9BPO Greg
DJ4JZ
Post by DJ4JZ »
Hi Greg,
I use Log4OM Version 2.2.0.0 and I've not a problem with changing frequencies. I looked at the data stream and saw that Log4OM Version 2.2.0.0 sends the right frequencies.
Please try Log4OM Version 2.2.0.0 und test again. Let us know the result.
73 de DJ4JZ
M0VON
Post by M0VON »
This seems to be a general problem with Yaesu rigs. I have the same issue with my FT-950. and others have reported similar issues in the forum.
If clicking the cluster causes a change of mode, then the resulting frequency is offset. Double-clicking the cluster again sets the correct frequency because the mode doesn't have to change.
I wrote a CAT program recently and found in general for the FT-950 that if the frequency is changed before the mode, then the resulting frequency is wrong, but if the mode is changed before the frequency then it is ok. Seems like a CAT commend sequence issue that may be unique to Yaesu ?
Graham, M0VON
F4BPO
Post by F4BPO »
Thanks Graham for explanation.
I am of course using 2.2.0.0 to reply to DJ4JZ.
OK so for now I will remain on v1 as it is perfectly working on v1. Hope this can be addressed by changing mode first before frequency.
Thanks again
73 de XV9BPO Greg
NN7D
Post by NN7D »
Checking on this. There is an option in V1 to send Freq before Mode. I can't find that option in V2... I've asked Danielle...
Doug - W7DRM
F4BPO
Post by F4BPO »
Thanks Doug as this is a real problem to be honest :(
73 de XV9BPO Greg
