Is it possible to add and save Telnet commands to select from drop list as it was in V1?
Mike / KA4CDN
Custom Telnet commands
Re: Custom Telnet commands
I don't have a New button or I'm not finding it.
I see a New button for adding a server. I've done that.
But I don't find a way to add a custom command such as "sh/dx on 160M".
If I remember in V1 there was a custom file where I added my commands.
Mike / KA4CDN
Mike / KA4CDN
Sorry I missundeŕstood
You need to edit the cluster command file which if I recall is in the config/user folder
Thank you Terry. I found the file and yes that worked.
On my install, which I accepted all defaults on a Windows 7 system, the file to edit was:
C:\Users\KA4CDN\AppData\Roaming\Log4OM2\clustercommands.txt
Cheers,
Mike
Cheers,
Mike
This works great but hoping they add buttons to bottom of cluster window so I can execute those cluster commands with a user friendly name attached.
