Using WSJTx and passing log info to Log4OM via UDP, I have had no problem doing an autopost of log info to QRZ for instance. I see the log refresh and then the info is uploaded to QRZ very quickly. Call A is logged and call A is posted to QRZ immediately.
I have just started using JTDX and using the instructions on page 140/141, I have a UDP JT Message and ADIF being monitored by Log4OM V2 I also CHECK {ENABLED} next to upload to external DB (QRZ).
At first it was failing to upload but now it seems to hold 1 call in a buffer before posting to QRZ, ie I work K1AAA, it is in the log but not posted to QRZ. I then work K9RRR, when this call goes in the log - K1AAA is THEN posted to QRZ. I have to work another stations before K9RRR goes to QRZ.
Is this normal?
In the manual on p139 I see a totally different way to move/connect to JTDX - WIll it be faster? Does it do the call buffer to external DBs?
Greg
K9IG
