Log4OM QSO uploads being stopped by JTalert
KN4ORP
Post by KN4ORP » 15 Feb 2020, 16:44
I am having QSO Automatic upload problems. My QSO's do not automatically upload to online logs if I have JT-Alert running. What setting do I have messed up that is causing this.
Re: Log4OM QSO uploads being stopped by JTalert
Post by DF5WW » 15 Feb 2020, 17:25
Please check on the external services side it´s uploaded or not. I´ve seen that all my contacts
was uploaded but from time to time the QSO send message wasn´t set to "YES". Hasn´t to do
anything with JTalerts i think.
By the way, please also check this thread: viewtopic.php?f=31&t=4828
73´s .. Juergen ... ALT-512 SDR (10W) , 2 x 6,5 mtr. indoor wire at CG-3000 autotuner ...
KN4ORP
Post by KN4ORP » 17 Feb 2020, 03:10
They definitely do not automatically upload online logs if JT -alert is running. I did not have JT-Alert running and made a contact and it Automatically uploaded to the online log books . I then started JT alert and made 6 contacts that did not automatically upload to the online log books. I then shut JT Alert down again and made another contact and it automatically uploaded to the online logs. The 6 contacts in between the two that auto uploaded had to be done manually.
W7DRM
Post by W7DRM » 18 Feb 2020, 08:03
KN4ORP wrote:
15 Feb 2020, 16:44
Ok guys, read the FAQ's. You could save the support team a lot of time and save you waiting time if you follow the
FAQ and give us complete info when you report an issue. #1 item is the Log4OM V# please!
