Hi folks , just started using the programme, sincere thanks to all for the work you do.
I am running a kenwood ts 590
Omnirig
I think cat is working because I have a green light at the bottom left and when I double click on a cluster spot the radio goes to the frequency and changes the mode.
Using usb cat cable and running the programme as admin.
The digital readout top left says offline.
Can I switch this on somehow?
Sorry if already discussed I have had a look on the forum, videos and the manual.
Regards
John GM0AZC
Offline
Re: Offline
Is the TS590 set up as rig 1 or 2?
Is there another radio on rig 1 or 2 and if so is it turned on or off?
Connection via USB or ACC socket?
What version of Log4OM? - see help/about
Windows version is ?????
Are any other programs running?
We need this type of information to help diagnose your issue otherwise its like you phoning the garage and just saying 'my cars gone wrong!'
Re: Offline
Hi Terry thanks for the quick reply.
The ts590s is set up as rig 1
No other radio.
Usb cat cable.
I am at work just now but version 2
Will double check when home.
Windows 10
I do have wsjt-x installed but not running.
John GM0AZC
No other radio.
Usb cat cable.
Windows 10
John GM0AZC
Re: Offline
When you return home ensure that rig 2 is set to NONE
Check that the configuration/CAT menu is set to auto start CAT when the program is started
Ensure that WSJT is set to Omnirig Rig 1 - Not TS590
Set rig selection to Rig 1 then close and restart Log4OM
