Just about to give up, yes its FLDigi :(
Re: Just about to give up, yes its FLDigi :(
Follow our user guide for wsjt set up USB-D works automatically and fine
OK Terry, I'll bite on this and maybe learn something.OK to put this one to bed once and for all, I have set up my IC7300 as I suggested above and it all works 100%
In my experience using Log4OM ADIF log following with FLDigi using the instructions in the manual does not work 100%. Specifically:
- The most recent Log4OM user manual suggests following C:\Users\YOUR USER
NAME\fldigi.files\logs\Logbook.adi. While that file uses ADIF syntax, the data in it is FLDigi/FLLog specific and does not contain SUBMODE entries. If you log an entry in a mode like Olivia, the result will be a non-compliant mode in your Log4OM log.
- FLDigi does create an ADIF 3.x compliant entry for each logged record, but it is in the ephemeral file c:\Users\<login>\fldigi.files\temp\log.adif. Following this file with Log4OM rather than the recommended one results in compliant entries.
Dale
Dale
If you are using the FLDigi interface you can change what mode FLDigi requests fldigi.files\frequencies2.txt. Default is USB but different rigs might have better modes (for flex PKTUSB is preferred). The FLDigi rig control popup will show you the options it understands.
Dale
Dale
Yes, the only one that works correctly with the Icom is "PktUSB" which selects "USB-D" on the radio. But LOG4OM does not use "USB-D" AFIK as its not an ADIF mode, i was just wondering what it shows when FLDigi selects itAE6DS wrote: ↑20 Aug 2020, 20:58 If you are using the FLDigi interface you can change what mode FLDigi requests fldigi.files\frequencies2.txt. Default is USB but different rigs might have better modes (for flex PKTUSB is preferred). The FLDigi rig control popup will show you the options it understands.
You should ask that question in the FLDigi forum because its not a Log4OM problem.M7DJK wrote: ↑21 Aug 2020, 05:23Yes, the only one that works correctly with the Icom is "PktUSB" which selects "USB-D" on the radio. But LOG4OM does not use "USB-D" AFIK as its not an ADIF mode, i was just wondering what it shows when FLDigi selects itAE6DS wrote: ↑20 Aug 2020, 20:58 If you are using the FLDigi interface you can change what mode FLDigi requests fldigi.files\frequencies2.txt. Default is USB but different rigs might have better modes (for flex PKTUSB is preferred). The FLDigi rig control popup will show you the options it understands.
FLDigi dictates the control of your radio in this scenario not Log4OM
FLDigi records the digital mode used like PSK31, RTTY, CW etc in the ADIF file and that is the information logged by Log4OM
You are correct USB-D is not an ADIF mode no more than the Yaesu 'USER' mode and is not recorded in a QSO by any logging software.
Ah. Log4OM should pick up MODE and SUBMODE from the FLDigi ADIF file not the rig. Or at least that’s what happens with my configuration (but note my previous post about different FLDigi files and ADIF compliance).
Eg, for an Olivia QSO Log4OM correctly shows “<MODE:6>OLIVIA <SUBMODE:12>OLIVIA 8/250” not PKTUSB even though the latter was the rig setting.
Dale
Dale
Thank you for this information I have amended the user guide accordingly although we have not had a problem with other modesAE6DS wrote: ↑20 Aug 2020, 20:35OK Terry,OK to put this one to bed once and for all, I have set up my IC7300 as I suggested above and it all works 100%
OK, thanks guys, there seems to be some confusion about logging data and rig/CAT control.
I am only referring to the issues i had earlier in the thread about rig control, not logged data.
I will drop the subject now as hopefully things will be sorted fine when my cat cable arrives.
Thanks for the help so far though.
I had a look at this, i can see the file in TEMP but it seems its not updated as much as the live log file, not idea why but mine is a few weeks behind, if it gets updated at, will keep an eye on it.
For now though it seems the only "live" log is the one selected in FLDigi Log menu.
