QSO Bulk Editor - Remember selected QSOs?
KZ3L
Post by KZ3L »
When bulk editing QSOs via the QSO Manager, is there a way to remember the QSOs that were selected in the "Search QSO" pane so that multiple changes can be made to the same set of QSOs?
For example, if I select 20 QSOs from my latest "Parks on the Air" park activation and attempt to use the Single field update or the QSO Checks tabs, after executing one change, all QSOs are deselected, forcing me to return to the "Search QSO" pane and select that same list of 20 QSOs again before changing another field.
This can become unwieldy when making multiple changes to the same set.
Is there an easier way? What am I missing?
Re: QSO Bulk Editor - Remember selected QSOs?
The best plan is to use the filters to refine the selection before you start bulk editing, then its just a case of clicking on 'Select all' after each edit
KZ3L
Post by KZ3L »
Thanks, Terry. Yes, the filters do simplify this, but it sure would be nice to have the QSO Manager remember my selection.
If you think this is a reasonable feature enhancement I'll post in that section of the forum.
Thank you,
Kevin
