Trigger qrz.com lookup after import
df9hc
Post by df9hc »
when I import QSOs from N1MM+ or similar to Log4OM I don't have the name information from qrz.com like I would have if I entered the QSO manually to Log4OM. Can I somehow trigger the lookup after import to complete the information? Could not find anything.
73 Haiko
Re: Trigger qrz.com lookup after import
OSO Manager, select all the imported contacts and hit "Update Info". That should work.
df9hc wrote: 29 Aug 2020, 08:13 Hello,
73 Haiko
How are you importing the N1MM qso's?
df9hc
Post by df9hc »
G4POP wrote: 29 Aug 2020, 08:49 How are you importing the N1MM qso's?
That's easy: in N1MM export as ADIF and in Log4OM import ADIF.
df9hc wrote: 29 Aug 2020, 14:38
Why dont you use the automatic method that I detailed in our user guide, so that when you log in N1MM the QSO is automatically passed to the log4OM logbook and updated from the on line lookup like QRZ automatically - That way you have nothing to do!
df9hc
Post by df9hc »
G4POP wrote: 29 Aug 2020, 14:47 Why dont you use the automatic method that I detailed in our user guide, so that when you log in N1MM the QSO is automatically passed to the log4OM logbook and updated from the on line lookup like QRZ automatically - That way you have nothing to do!
I didn't know that, also using N1MM only rarely.
Jürgen's method worked perfectly.
Edit: how to use this automatic method? I just search the (German) user manual and found only 1 reference to N1MM saying that it's possible to use N1MM parallel to Log4OM - that's all. Is the German translation missing a lot of information?
df9hc wrote: 29 Aug 2020, 14:52
I don't know as I don't speak German but it's in the original user guide I wrote
Hello Haiko,
we don´t have a german translation at the moment. V2 is to fresh and a lot of changes
every day. If i´m not longer in my fulltimejob and i have more time i will try to do the same
as i did for V1 .... Creating a german translation.
:P :P
By the way, try the Connections in the setup and let N1MM directly send to V2. Check the manual
for this. We can handle ADIF Messages via UDP from N1MM via UDP support. So no export/import
needed. The manual will tell you more about this. In english a.t.m.
