All:
I have Log4om CAT connected to Slice Master via TCP port (see attached). It works flawlessly, but I need to open the Log4om CAT interface and connect manually each time I start the logger. I'd like to have it connect automatically and was wondering if there's a parameter in Log4om that allows for that? I've tried starting the Log4om first and then Slice Master as well as vise-versa but that doesn't seem to matter.
Tony
Slice Master TCP CAT
Re: Slice Master TCP CAT
You need to ask the Hamlib developer because we did not write that software.
I have the same issue with my flex so I live with just display of one slice and use Omnirig which connects without me having to do anything.
In the Configuration / Hardware Configuration / Cat : check the cat autostart
- 2021-05-05_22-32-55.jpg (53.21 KiB) Viewed 1663 times
Its a different connection in latest Hamlib and I do have autostart checked but that starts Hamlib it does not connect Hamlib
