Sorry guys, I didn't understand the iteration between Log4OM and CWSkimmer.
Control of the RIG passes via Omnirig but if I click on one of the callsigns only the frequency changes but nothing else happens.
On CWSkimmer I set Network-> Enable Telnet server (7300) and Allow SKIMMER.
Do I forget something?
Tnx in advance.
Max
CWSkimmer and Log4OM V2
Max IK0TIX
Max IK0TIX
Re: CWSkimmer and Log4OM V2
In Log4om did you connect to the CWSkimmer DX-Cluster telnet server (127.0.0.1:7300). CW-Skimmer is also DX-Cluster, so you can connect to it and everything it decodes is send as a DX-Cluster spot to Log4OM.
I use a Red-Pitaya that can monitor 8 bands simultaneously together with CWSkimmer-server (is free if you buy CW-Skimmer), so i get DX-cluster spots from 8 bands in Log4OM from my own antenna, this means everything it spots i can work. That works so good that i hardly connect to a internet DX-Cluster anymore.
