Since the recent upgrade, I am no longer seeing My References in any of the grids. If I open up a QSO in the Edit screen, it is there. Also, if I use a filter and screen for any of My References, it works and shows up in the grids. But without a filter applied, I cannot see any of My References.
Am I missing a setting?
Thanks,
Ron, NR3E
My References Not Showing Up
Re: My References Not Showing Up
Ron,NR3E wrote: ↑10 Jul 2021, 13:38 Since the recent upgrade, I am no longer seeing My References in any of the grids. If I open up a QSO in the Edit screen, it is there. Also, if I use a filter and screen for any of My References, it works and shows up in the grids. But without a filter applied, I cannot see any of My References.
Thanks,
Ron, NR3E
Check the Table Layout for the Grid(s). Be sure the column you want is tic'd.
- MyRefsGrid.JPG (34.9 KiB) Viewed 2828 times
Thanks, Nolan, but My References was checked. In fact, I unchecked it and checked it again with the hope something would reset. As you can see in the following grid, no My References are showing up. These should show W4T-RV-023. This is just an example, none are showing up in the grids.
Thanks,
Ron, NR3E
Thanks,
Ron, NR3E
- Screenshot.png (86.3 KiB) Viewed 2826 times
Ron,
Sry about that. Oft-times the display of a column can get in-advertently checked on/off.
That being said ... take a look at Settings / Configuration / My References to see if that might help solve or provide a clue.
Thanks again, Nolan, but that was no help either. Actually, I change My References with each SOTA activation that I input, using only the SOTA designator for that particular activation. The references just aren't showing up in the Recent QSO (the main grid) or the QSO Management grid. They were always there before the last update and I haven't done anything different, me thinks. But if I double click on a grid line to edit a record, the reference is listed.
Thanks again,
Ron, NR3E
Thanks again,
Ron, NR3E
Ron,
It is a hiccup and now on the "repair" list.
I found the internal versions where it stopped appearing.
Thanks, Nolan, you are the man!
Ron, NR3E
Ron, NR3E
I am also seeing this. I just wanted to mention I am seeing it for both "My References" and "Contact References"
Greg - KJ7EHA
Greg - KJ7EHA
- Log4OMScreenshot2.jpg (245.2 KiB) Viewed 2740 times
Thanks to the team for all your great work. I had hoped this issue would be fixed with the latest release. Do we know if it is scheduled for a fix soon?
Thanks,
Ron, NR3E
Thanks,
Ron, NR3E
So should we log this to the "Error Reports" Forum?? I sure miss this feature.
