Hoping someone can help...... For an upcoming contest I have added a new mode in 'modelist' and selected it in the user configuration and I can select it both from the main log and the contest log screens. The problem lies in that it is showing the RST as 599 and it is a phone mode requiring a 2 digit RST.
I can see in the RSTlist where the format is defined for the different emission types but can not see how I can associate my mode (PH) to be emission type (phone) to give it the required RST format.
I have entered my new mode as a submode of SSB as far as I can tell in modelist by entering PH;PH;SSB;PH but to be honest I am struggling to work out the format and meanings of some of the list files.
Any pointers greatly appreciated.
Simon M0ZRT
Setting RST Format for New Mode
Re: Setting RST Format for New Mode
This is the recognised mode list, anything other may not be accepted for confirmations and log uploads to award and contest managers, why do you require the odd format?
https://www.adif.org/312/ADIF_312.htm#Mode_Enumeration
Many thanks for the Quick reply, its for the SSB Field day this weekend, required format below, I have got a converter to change to Cabrillo but it wants PH as mode. Worst case I can just use SSB as the mode and then do a find and replace prior to converting to Cabrillo.
RSGB CW & SSB Field Days -- Example of Cabrillo log
Notes: (1) The robot will determine the correct Section from the dialogue during log entry.
(2) For SSB Field Day replace "RSGB-NFD" by "RSGB-SSB-FD" & "CW" by "PH"
START-OF-LOG: 3.0
CONTEST: RSGB-NFD
CALLSIGN: G3GRS/P
CLAIMED-SCORE: 3238
OPERATORS: G4BUO G0HSS G0FDZ
CLUB: Gravesend Radio Society
NAME: C. Secretary
ADDRESS: 12 Acacia Walk
ADDRESS: Neasden
ADDRESS: London
ADDRESS: g4xyz@contesting.com
SOAPBOX: Good conditions
SOAPBOX: IC756PRO and 270ft doublet, centre up 35ft, running E-W
QSO: 14012 CW 2017-06-03 1501 G3GRS/P 599 001 G3UES/P 599 003
QSO: 14028 CW 2017-06-03 1503 G3GRS/P 599 002 G3XSV 599 005
QSO: 14033 CW 2017-06-03 1504 G3GRS/P 559 003 DL0CS/P 599 002
QSO: 14033 CW 2017-06-03 1506 G3GRS/P 599 004 R3UA/P 599 005
QSO: 21003 CW 2017-06-03 1507 G3GRS/P 599 005 IK4NTF 599 005
QSO: 14033 CW 2017-06-03 1508 G3GRS/P 599 006 DL0LA/P 599 009
QSO: 7025 CW 2017-06-03 1509 G3GRS/P 599 007 G3TBK/P 599 001
QSO: 7012 CW 2017-06-03 1511 G3GRS/P 599 008 G0IVZ 599 005
QSO: 7040 CW 2017-06-03 1511 G3GRS/P 599 009 DL0CS/P 599 012
QSO: 3514 CW 2017-06-03 1513 G3GRS/P 599 010 GM3POI/P 599 002
QSO: 3521 CW 2017-06-03 1515 G3GRS/P 599 011 M0ABC/P 599 002
QSO: 3525 CW 2017-06-03 1516 G3GRS/P 599 012 G4BWP 599 012
END-OF-LOG:
START-OF-LOG: 3.0
CONTEST: RSGB-NFD
CALLSIGN: G3GRS/P
CLAIMED-SCORE: 3238
NAME: C. Secretary
ADDRESS: Neasden
ADDRESS: London
END-OF-LOG:
You will be best to use a converter because otherwise any other uploads like to LOTW etc will reject the mode if it's not ADIF format
Ok Terry, thought I may be over complicating things.
Many thanks, Much appreciated
