Moving SQL Lite database to the cloud
When I originally set up Log4OM I hosted the database on my local computer. I now want to move it to OneDrive so that I can access it from more than one computer. I realise I could export the whole database as an ADIF file, then set up a new one in the cloud, import everything to it and delete the old one, but is there a simpler way?
Re: Moving SQL Lite database to the cloud
Have you tried to copy the complete database into a place of your OneDrive folder and change the
link to the database in your Log4OM settings ? That should be the easiest way.
Just copy the sqlite file to your cloud storage then in File/open (New) database navigate to the new location and open it followed by Save and apply.g3yiq wrote: ↑26 Sep 2021, 09:18 When I originally set up Log4OM I hosted the database on my local computer. I now want to move it to OneDrive so that I can access it from more than one computer. I realise I could export the whole database as an ADIF file, then set up a new one in the cloud, import everything to it and delete the old one, but is there a simpler way?
Be aware that using OneDrive may require you to rum Log4OM as an administrator due to the Microsoft security system.
Thanks, Terry. That's a little more elegant!
73 Bob
73 Bob
