I have just downloaded Fldigi, I am trying to get the CAT control to work along side the CAT contol for Log 4 OM to no Avail. I notice on Log 4 OM there is a tab "connect" when you click here and select Fldigi Connect, what does this actually connect? because it doesn't seem to have an affect on anything within the program.
any help and advise would be gratefully received.
Garry
Fldigi
Re: Fldigi
Garry,
Download the most current User Guide and open in your PDF viewer. Search for "FLDigi" and you will find many locations in the UG that should be able to help you out.
The main FLDigi integration starts on Page 212.
