Import from v1 - V2 lot of KG4's converted from US to Guantanamo Bay
N5ZY
Post by N5ZY » 19 Jan 2020, 23:49
First: Thank you everyone for all the hard work that has been invested in v2!
Sending donation now!
Just fyi, the import (from V1's ADIF) resulted in all KG4 calls being converted from U.S. to Guantanamo Bay (DXCC 291 to 105).
Most others were corrected from 0 to a real country.
The few /MM's were converted to DXCC 0
And hilariously, one was converted from US to Russia (N0LD/R DXCC 291 to 54)
(It's hilarious because he lives just down the road).
20:35:38: Begin ADIF import
20:35:41: Callsign: Z35T Date: 04-Jan-20 10:42:30 PM Band: 40m Mode: FT8 Country has changed from Macedonia to North Macedonia
20:35:43: Callsign: JG1LKT Date: 20-Oct-19 1:14:45 PM Band: 40m Mode: FT8 DXCC has changed from 0 to 339
20:35:43: Callsign: KG4YDW Date: 20-Oct-19 12:06:30 PM Band: 40m Mode: FT8 DXCC has changed from 291 to 105
20:35:45: Callsign: JF1DPF Date: 18-Oct-19 12:54:00 PM Band: 40m Mode: FT8 DXCC has changed from 0 to 339
20:35:47: Callsign: RM8T Date: 05-Aug-19 2:34:30 AM Band: 20m Mode: FT8 DXCC has changed from 0 to 15
20:36:01: Callsign: N0LD/R Date: 10-Jun-19 2:16:17 AM Band: 2m Mode: FM DXCC has changed from 291 to 54
20:36:01: Callsign: KG9DUK/R Date: 10-Jun-19 2:04:11 AM Band: 2m Mode: FM DXCC has changed from 291 to 54
20:36:03: Callsign: XE2MAM Date: 01-May-19 7:57:24 PM Band: 20m Mode: FT4 DXCC has changed from 0 to 50
20:36:07: Callsign: Y32BWC Date: 06-Jan-19 12:16:00 PM Band: 40m Mode: FT8 DXCC has changed from 0 to 230
20:36:14: Callsign: VA6SS Date: 02-Dec-18 3:23:34 AM Band: 80m Mode: FT8 DXCC has changed from 1 to 291
20:36:15: Callsign: VA6SS Date: 02-Dec-18 12:47:30 AM Band: 40m Mode: FT8 DXCC has changed from 1 to 291
20:36:23: Callsign: YU2AX/MM Date: 11-Sep-18 12:47:00 AM Band: 30m Mode: FT8 DXCC has changed from 296 to 0
20:36:26: Callsign: KG4IYS Date: 27-Aug-18 10:15:00 PM Band: 30m Mode: FT8 DXCC has changed from 291 to 105
20:36:36: Callsign: NA0BB Date: 25-Mar-18 7:56:02 PM Band: 20m Mode: SSB DXCC has changed from 0 to 291
20:36:36: Callsign: KG4CRJ Date: 25-Mar-18 6:54:38 PM Band: 20m Mode: SSB DXCC has changed from 291 to 105
20:36:38: Callsign: VE5AO Date: 25-Mar-18 1:23:24 PM Band: 40m Mode: SSB DXCC has changed from 0 to 1
20:36:38: Callsign: KG6CFW Date: 25-Mar-18 6:10:53 AM Band: 40m Mode: SSB DXCC has changed from 0 to 291
20:36:40: Callsign: 7W8T Date: 25-Mar-18 2:31:03 AM Band: 40m Mode: SSB DXCC has changed from 0 to 400
20:36:42: Callsign: JI2JEY Date: 24-Mar-18 9:22:41 AM Band: 40m Mode: SSB DXCC has changed from 0 to 339
20:36:44: Callsign: KG4USN Date: 24-Mar-18 5:31:56 AM Band: 80m Mode: SSB DXCC has changed from 291 to 105
20:36:44: Callsign: VVE4VT Date: 24-Mar-18 5:26:11 AM Band: 80m Mode: SSB DXCC has changed from 0 to 324
20:36:49: Callsign: YU2AX/MM Date: 16-Feb-18 11:56:00 AM Band: 40m Mode: FT8 DXCC has changed from 296 to 0
20:36:50: Callsign: UA9FFV Date: 12-Feb-18 1:22:00 PM Band: 30m Mode: FT8 DXCC has changed from 15 to 54
20:36:58: Callsign: N47E Date: 12-Nov-17 12:55:35 AM Band: 40m Mode: SSB DXCC has changed from 0 to 291
20:37:00: Callsign: VE7150 Date: 29-Oct-17 10:11:10 PM Band: 20m Mode: SSB DXCC has changed from 0 to 1
20:37:01: Callsign: HC0E Date: 28-Oct-17 3:49:20 PM Band: 15m Mode: SSB DXCC has changed from 0 to 120
20:37:02: Callsign: VC3X Date: 28-Oct-17 2:00:44 AM Band: 40m Mode: SSB DXCC has changed from 0 to 1
20:37:07: Callsign: KG4ZXN Date: 30-Sep-17 5:38:45 PM Band: 17m Mode: FT8 DXCC has changed from 291 to 105
20:37:07: Callsign: KG4ZXN Date: 30-Sep-17 5:38:00 PM Band: 17m Mode: FT8 DXCC has changed from 291 to 105
20:37:08: Callsign: KG4GEK Date: 19-Sep-17 4:03:30 PM Band: 20m Mode: FT8 DXCC has changed from 291 to 105
20:37:08: Callsign: KG4GEK Date: 19-Sep-17 4:03:00 PM Band: 20m Mode: FT8 DXCC has changed from 291 to 105
20:37:25: Callsign: KF0DH Date: 03-Aug-17 3:29:45 PM Band: 20m Mode: FT8 DXCC has changed from 0 to 291
20:37:25: Callsign: KG4FNG Date: 30-Jul-17 3:51:15 PM Band: 20m Mode: FT8 DXCC has changed from 291 to 105
20:37:25: Callsign: KG4FNG Date: 30-Jul-17 3:51:00 PM Band: 20m Mode: FT8 DXCC has changed from 291 to 105
20:37:25: Callsign: N4AA Date: 30-Jul-17 3:17:45 PM Band: 20m Mode: FT8 DXCC has changed from 0 to 291
20:37:40: Callsign: KG4JYB Date: 08-Mar-17 2:32:00 PM Band: 20m Mode: JT65 DXCC has changed from 291 to 105
20:38:39: Callsign: N0HJZ Date: 01-Feb-14 6:47:22 PM Band: 20m Mode: SSB DXCC has changed from 146 to 291
20:38:39: Callsign: VK6FZM/MM Date: 22-Jan-14 1:10:32 AM Band: 20m Mode: SSB DXCC has changed from 150 to 0
20:38:43: Callsign: Z320T Date: 20-Aug-13 11:26:48 PM Band: 20m Mode: SSB Country has changed from Macedonia to North Macedonia
20:38:50: SEARCHING AWARDS REFERENCES...
20:38:56: End of ADIF import
20:38:56: Begin LOG save
20:39:04: LOG saved
20:39:04: Save completed
Marcus Sutliff/N5ZY
Edmond Amateur Radio Society President
License Class Coordinator.
ARRL Volunteer Examiner
http://www.k5eok.org
http://www.qrz.com/db/N5ZY
N6VH
Re: Import from v1 - V2 lot of KG4's converted from US to Guantanamo Bay
Post by N6VH » 24 Jan 2020, 17:40
Just a suggestion - uncheck "Apply country corrections on load". Then you will get a list of suggestions for corrections that might need to be made. Most of the countries should already be correct, if they were correct in v1.
