Edit QSO: edit Freq removes references
Posted: 15 Feb 2020, 05:36
by KJ7EHA
I have found that if you edit an existing QSO and edit the Freq field, that when you "Save" it clears all references, both My Refs and Contact Refs.
Are other users seeing this issue?
Re: Edit QSO: edit Freq removes references
Posted: 15 Feb 2020, 19:28
by OE5JFE
Yes, same for me.
I just edited an exising QSO and both the Award Refs. and the My Refs. is empty after saving.
73 Joe
Posted: 15 Feb 2020, 19:37
after editing the frequency, the band changed?
ok, found and fixed. We're testing it internally
Posted: 15 Feb 2020, 19:44
by KJ7EHA
I notice that when I edit Freq, that yes the Band field correctly changes as I am in the edit window. The band correctly matches the Freq. After I click on "Save" is when the associated References get cleared.
I notice also that the references get cleared if I change the "Mode." I changed from FM to SSB and references cleared.
Posted: 15 Feb 2020, 19:55
by OE5JFE
I had no frequency entered before and just entered a value matching with the selected band.
73 Joe
