LoTW upload freezes
WB8AM
LoTW upload freezes
Post by WB8AM »
Hello all,
I am running v.2.7.0.0 and TQSL version 2.5.4. I've suddenly noticed with the upgrade to 2.7.0.0 that my LoTW uploads get stuck. Here is what I see (sorry, I'm running remotely and can't seem to get a proper screen grab):
INFO: ADIF File created successfully.
INFO: TQSL Version 2.5.4
No private TQSL Password set
Executing TQSL with upload
and that is where it stops. I've double checked my settings "User" (which is the LoTW login username, correct?), TQSL exe path, Temporary path, Station ID. After this happens I notice that L4OM has to perform a forced closure. Any help is appreciated!
Thanks,
Brian WB8AM
WB8AM
Re: LoTW upload freezes
Post by WB8AM »
Update, I reverted back to 2.6.0.0 and the same thing is happening. Could my SQLite file be corrupted? I suppose next step is to try one of my backups?
Thanks,
Brian
WB8AM
Post by WB8AM »
The backup route did not work either. Unfortunately, I'm not sure how to debug this any further.
Thanks,
Brian
Please email me direct and I will provide a download for you to try
Email is as on QRZ
WB8AM
Post by WB8AM »
Thanks Terry,
Email sent.
Very best, Brian
DK9JC
Post by DK9JC »
TQSL 2.5.4. and 2.7.0.0 working perfect here. Win 10 latest build.
https://www.dk9jc.de
WB8AM
Re: LoTW upload freezes - SOLVED!
Post by WB8AM »
SOLVED!
Major shout out to Terry & Daniele for working with me to solve this issue.
The problem: LoTW uploads were freezing which caused L4OM to not shut down gracefully. No error messages were indicated.
The troubleshooting: Terry recommended that I use an ADIF export of one of the trouble QSOs to upload directly to LoTW via TQSL. TQSL does not report errors back to L4OM, so this step was critical in finding the solution. During upload I discovered that my QSO ITU Zone and CQ Zones did not match my TQSL cert (I'm in the US and we have 3 ITU Zones... I chose the wrong one in L4OM.)
The solution: First step was to update my L4OM settings to the correct ITU/CQ Zones. Next I used the "Single Field Updater" in QSO Manager to update the zones and problem solved. LoTW accepted my upload without any further issues.
Thanks guys!
Brian WB8AM
DK9JC
Post by DK9JC »
WB8AM wrote: 22 Jun 2020, 18:03 (I'm in the US and we have 3 ITU Zones... I chose the wrong one in L4OM.)
Thank you for reporting back what caused the problem. Very strange thing. :o
DO1MFB
Post by DO1MFB »
Exact the same problem und exact the same solution !!!
Thanks, 73
Martin DG2MB
