Hi All,
Upgraded to 2.12.0.0 from 2.11.0.0 and have noticed some unexpected changes.
1. When I go to View / Award Status and select DXCC . . . wait for it to refresh . . . when I you click the drop down on the "Predefined Config" it appears to be an abbreviated list compare to what was available in 2.11.0.0. Is that by design? Is there a way to obtain the original list? (no Mixed, no Digital, no HF Individual bands).
2. Of greater concern, I had ARRL process some cards today that I had field checked. Due to the small number of QSOs I decided to manually set the "Awards Ref". To my surprise it when I went to select the appropriate DXCC settings there was no Mixed, no Digital, no HF individual bands.
What is the appropriate action to take to resolve the above issues which I expected are related.
I have verified with a fellow Log4OM user who did the 2.11.0.0 to 2.12.0.0 upgrade and is seeing the same thing.
Any suggestions is appreciated.
Cheers es 73,
Daniel VE3NI
Missing Predefined Reports for DXCC
Re: Missing Predefined Reports for DXCC
I can confirm that you have found a bug and will notify lele about it.
Please be patient while we resolve this and issue a maintenance release
Thanks for the quick reply and confirmation.
Will standby for a resolution.
Cheers es 73,
Daniel VE3NI
Cheers es 73,
Daniel VE3NI
I am really confused now.
It appears as though all the predefined reports are back and functioning.
In addition all the band options are available in "Award Ref" are back.
Does any of this make sense?
I have not made any changes, I did not roll back to an earlier version and I did not reinstall 2.12.0.0.
The only thing that I know I changed was the starting the program to "Run as Administrator" per the instructions on page 14 to facilitate the interoperability of OMNIRig, JTDX and Log4OM. I would not think that would be a factor.
Scratching my head but with a BIG SMILE.
Cheers es 73,
Daniel VE3NI
Cheers es 73,
Daniel VE3NI
Your awards were automatically updated with the revised awards file
Thank you for the explanation.
There is so much to explore and learn about this great program.
I appreciate all the support.
Daniel VE3NI
Daniel VE3NI
Hi All,
Just a heads-up.
Installed 2.13.0 and not all the "Predefined config" reports for the DXCC Award are displaying again.
I will wait for a revised awards file to be pushed.
Thanks.
Cheers es 73,
Daniel VE3NI
Just a heads-up.
Thanks.
Cheers es 73,
Daniel VE3NI
LOL
Okay . . . see that it has been pushed out.
Thanks.
Daniel VE3NI
Thanks.
Daniel VE3NI
