Click on cluster spot not working with hamlib
w9mdb
Post by w9mdb »
Clicking on a cluster spot does not set mode or frequency using hamlib.
I don't see any activity in the log file to talk to hamlib at all.
Re: Click on cluster spot not working with hamlib
w9mdb wrote: 05 Apr 2021, 18:30 Clicking on a cluster spot does not set mode or frequency using hamlib.
Mike,
FWIW - I'm running Hamlib here with my K3. Clicking cluster spot will change freq/mode, but is quite slow and I've tweaked the polling delay time to test as well.
I have my log open and running in Trace mode and (as you noted) there is no comment in the log about the Hamlib action when clicking on a cluster spot.
w9mdb
Post by w9mdb »
Was reporting for a friend. Just tested on my system and it's working.
So he must have something set up incorrectly.
w9mdb
Post by w9mdb »
Well...it was working and the stopped again...
I see the "Sub" vfo being requested when clicking on a spot (on both PowerSDR selection and on an IC-7300 too).
Neither rig has Main/Sub vfos and I don't see get_vfo_list being called to see the available vfos.
w9mdb
Post by w9mdb »
This has been fixed in the latest alpha version.
