2 callsigns and LoTW upload
F6EXV
Post by F6EXV »
Hi
I am using V2.13.0, with 2 different callsigns. Both are configured to automatic upload upon quitting the program.
If and when I switch callsigns within one Log4OM session, only the current one is uploaded.
Shouldn't both be uploaded upon exiting ?
Or am I missing something in the config ?
Thanks + 73
Paul F6EXV
Re: 2 callsigns and LoTW upload
Active call will be uploaded after close. So they have different TQSL certificates. For uploading
the second call you have to activate this setup and then close Log4OM again. The "problem" is TQSL
and it´s different certificates. Think Lele can´t do anything in that case.
F6EXV
Post by F6EXV »
Hello Juergen
Aren't both certificates somewhere in Log4OM ?
When exiting, couldn't the program upload one callsign, change call and upload ?
Thanks + 73
Paul F6EXV
No the certs ate in Tqsl program
F6EXV
Post by F6EXV »
Hi Terry
But Log4OM has access to them.
My idea is, when several callsigns are used (several starts with 2), exiting the program would upload the current log QSOs, and check the other database(s) for QSOs to upload, if any.
That is automate the process on exit.
Thanks + 73
Paul F6EXV
F6EXV wrote: 30 Apr 2021, 18:39 Hi Terry
It could access both certs but Log4OM does not do that and there is no provision for you to set Log4OM up to function like that.
What you are suggesting is an 'idea' for a future feature to be implemented not a current function.
F6EXV
Post by F6EXV »
Terry
You are right. I was initially inquiring if this could be achieved under present config.
Since it is not, then it becomes a suggestion for a future version.
Thanks + 73
Paul F6EXV
