The Winkey interface cannot now be sized as small as previous versions which has caused an issue in my multiple monitor setup.
It would be nice if we could resize this to whatever size on screen we like even though some information within the interface will be hidden from view.
Version 2.14 Winkey Interface NOT sizeable small enough
73 James G0UJA
Re: Version 2.14 Winkey Interface NOT sizeable small enough
The concept is that you use the Winkeyer window stand alone with the main UI minimised
Understood, in that case it would be nice to have the band map added directly to this window like the main window.
73 James G0UJA
