WinKeyer not connecting
G3ZSS
Post by G3ZSS »
Log4OM v2.14.1.0
I cannot connect to my WK and get an error message "WK Echo test failed!". I downloaded the WK tools from the K1EL website and confirmed that WK is working correctly, but cannot get WK to work with Log4OM. It has worked correctly in previous versions in Log4OM.
73 Peter G3ZSS
G0UJA
Re: WinKeyer not connecting
Post by G0UJA »
My Arduino WK emulator (same principal as genuine WK) worked straight after upgrade as Log4OM appears to retain the settings from the previous Log4OM version so this may not be an issue with Log4OM.
Have you tried setting your WK to default settings in case a setting is incompatible or corrupt?
73 James G0UJA
Just checked and its all working fine as you can see.
Check the com port has not been changed or removed by the last windows update
G3ZSS
Post by G3ZSS »
I have not changed anything but it is working OK this morning!
73 Peter G3ZSS
