Log4OM V2 v2.14.1.0 on a Windows 10 Pro fully up to date machine with plenty of RAM/Hard Disk space:
F7 (Recent QSO's) tab, Lock Icon Clicked (it is RED), Selected multiple QSOs (rows) using CTRL-CLICK, the rows are highlighted in Blue, hitting the Delete Key does nothing, Hitting the Backspace key does nothing.
If i select only 1 row and hit the Delet Key it deles that row/QSO just fine.
On page 59 of the manual under the heading "Bulk deletions of QSO's" it indicates that this is the procedure to delete multiple QSO's (it calls it Bulk delete)
I believe this is a bug. Happy to help you debug this. Please also see screen shot attached below
73 de k1jbd
bammi
Screenshot image here:
https://ibb.co/Lr2D3Ch
Log4OM V2 v2.14.1.0 Bulk Delete Not Working
73 de k1jbd
bammi
bammi
Re: Log4OM V2 v2.14.1.0 Bulk Delete Not Working
I just tested this on all grids and it works fine for me
Are you sure the database is installed somewhere that is not a protected folder?
Thanks Terry,
Just realized that I should have mentioned that my Database is MySQL, the credentials I use to MySQL give me root privileges, so there should be no permission problems. As I mentioned I can delete 1 record at a time, so that pretty much proves that I do not have any permission related issues. Please can you try with a MySQL configuration instead of a sqlite DB.
Do you think this could be a MySQL related issue? If it matters I am running MySQL v 8.0.25 fully up to date with respect to any critical MySQL updates to 8.0.25.
73 de k1jbd
bammi
73 de k1jbd
bammi
73 de k1jbd
bammi
bammi
Were you able to test on a mySQL data base ?
73 de k1jbd
bammi
73 de k1jbd
bammi
73 de k1jbd
bammi
bammi
Did you update Log4om to 2.15? And try again?
Yes, no difference with 2.15
73 de k1jbd
bammi
73 de k1jbd
bammi
73 de k1jbd
bammi
bammi
