Does not shut down, backup not updated
G3ZSU
Post by G3ZSU »
Has been fine for a few days, but now, I get this dialogue box
Uploading LOTW data (120 second timeout)
Saving form status.......
Shutting down Log4OM application
And it hangs.
If I kill it with Task Manager, it does not back up and data to the default backup location.
SQL data seems intact.
A delete and reload has not solved the problem. In addition, I cannot set a desktop shortcut now.
Any help please?
Re: Does not shut down, backup not updated
Shaun,
Couple starting point questions here:
What version of Log4OM-2 are you using?
Do you have the most current version of TQSL installed? Current version is: v2.5.7 with configuration data of: v11.14
G3ZSU
Post by G3ZSU »
Hi, using Log4OM V2.15.0.0
TSQL 2.5.7
Have verified all TQSL login credentials.
Manual log-in using those credentials works OK
There is an ADIF file for every day in ....appdata\roaming\log4OM\temp
So it appears that tqsl.exe is not finding the [latest] .adi file.
Now running out of ideas
73 G3ZSU
G3ZSU
Post by G3ZSU »
Problem was to do with QSL status. Reset to default fixed the issue, although I had not changed anything as far as I knew. Didn't notice any change on screen. Anyway, problem solved.
