I have WK K3NG emulation, remotely connected via VSPE.
It works ok with DXLab WinWarbler.
In log4om v2.15.0.0 it connects to the keyer but only works the TUNE button. Text doesn't transmit.
This is my first installation of log4om, so I don't know if it works with previous versions.
I sniff the serial port traffic and I see log4om sending configuration command and tune request (when I press the button), but when I write free text or press a macro key, no traffic is sent on the port.
WK 2.15.0.0 don't TX
Re: WK 2.15.0.0 don't TX
I try with the same configuration and FLdigi, winkeyer works.
If you need further investigation please ask.
Keyer is "connected" aka enabled in log4om? what appears in the bottom left area of the keyer screen?
Re: WK 2.15.0.0 doesn't TX
Hi Daniele, you are doing a nice job with log4om. I'm switching from DX Lab to your logging software.
Yes, the log4om winkeyer interface connect to the WK, in the bottom left angle a green indication appears: "Winkeyer opened successfully. Hardware version 23"
As written before, only the "tune" button works. But not macro or manual text.
Johnny
Johnny
