QSOs uploaded to LoTW with wrong callsign
4X1ST
Post by 4X1ST »
A month or so back I did a short /P operation, and changed Station Callsign to 4X1ST/P in the settings (operator and owner callsign are blank). After uploading the contacts, I reverted it to 4X1ST.
Now intermittently, the LoTW upload seems to hang/freeze for hours on end, until I cancel it.
When that happens L4OM uploads the 4X1ST QSOs to LoTW as 4X1ST/P (even though that callsign isn't shown in the settings anywhere).
Any ideas what's happening please?
73 Tim
L4OM 2.21.1.0, Win 10
Re: QSOs uploaded to LoTW with wrong callsign
Have you changed also your LotW informations in the setup? Normally you need an extra information for a /P callsign like certificate and station information.
HB9BRJ
Post by HB9BRJ »
Update TQSL to latest version. From the TQSL release notes:
2.6.1: Fix a major error in handing previously uploaded QSOs that can cause TQSL
to either hang or keep asking how to handle those QSOs.
73, Markus HB9BRJ
4X1ST
Post by 4X1ST »
DF5WW wrote: 23 May 2022, 05:41 Have you changed also your LotW informations in the setup? Normally you need an extra information for a /P callsign like certificate and station information.
No, I didn't change the LoTW config when I did the /P QSOs. Its always set to my "home" location, although I do have a separate certificate for /P. I also have "Send My Station updated data to LOTW" set.
4X1ST
Post by 4X1ST »
HB9BRJ wrote: 23 May 2022, 06:47 Update TQSL to latest version. From the TQSL release notes:
73, Markus HB9BRJ
Thanks. I've updated TQSL now :)
It seems to have stopped the "hanging".
